Aullah
PC Specification: Phenom2 x4 965,gtx550ti 1gb oc, win7 64
Very weird sound problems with a game
Sat May 04, 2013 9:42 am
Hey! Its me again.
So I recently had problems with the screenshot capturing which is resolved by now. It works now. I have other problems...
I play with Neverwinter since launch and I had to put down ACTION and use another recording device, because with ACTION the sounds were off. Its hard to explain but some sound effects like my spells were very very quiet and sounded weird. But only for those sounds, others were ok. The funny thing is that when I was in the game, playing and recording, the sound was okay. Then I played the video I created and it was bad. Other capturing programs works without problem so I dont know what to do. Here is an http://www.youtube.com/watch?v=PMce7x_6tYE
Every other game works perfectly with ACTION except this.
Re: Very weird sound problems with a game
Wed May 08, 2013 1:18 pm
Do you record to AVI or MP4?
Aullah
Sun May 12, 2013 8:27 am
radi wrote:Do you record to AVI or MP4?
Oh sorry...
Yes. Im using 720p avi 30fps. I use this settings to every game and so far this game is the only where the sound is bad. Also I usa wav as my audio output format if this matters.
Aullah
Sun May 12, 2013 11:21 am
Im getting closer to the solution now: I can record gameplay from this game with NEVERWINTER, and the sound is fixed now. However... the only thing that plays the videofile is the ACTION PLAYER. I cannot open with media player classic and neither with vlc media player. I get this error message. What codec I need? Or I dont know...
Mon May 13, 2013 2:16 pm
Action! uses it's own FICV codec. Some applications doesn't recognize our codec.
vivan
Mon May 13, 2013 2:24 pm
Aullah wrote:I cannot open with media player classic and neither with vlc media player. I get this error message. What codec I need? Or I dont know...
It's impossible for vlc to decode video since vlc doesn't support vfw/DS codecs.
As for mpc - it says that it has problem decoding audio (which is simply 6ch uncompressed), that's odd. Try updating to latest version.
PS Vita, Nokia N8
Aullah
Mon May 13, 2013 2:53 pm
I will try it but the big problem is that sony vegas does not recognise audio part. I will fully reinstall this program, maybe it undo the fukup I made.
Aullah
Wed May 15, 2013 7:33 am
I did a full system reinstall. Everything works now. You can delete this post.
