Lightning-kun
PC Specification: Windos 8, GTX660, Core i7, RAM 16Gb
Audio Out of Synchronization
Sat May 18, 2013 12:35 am
I'm having a problem. Every game I record with Action, the AVI file comes with the Game's audio out of synchronization. My voice and the game's video are fine, but the game audio starts going out of sync from 5 minutes and it gets worse with every minute after.
My version is 1.14.1.0. I record with Original game resolution, 30 Fps, AVI, multi-channel and separated audio tracks.
locutus
PC Specification: Intel i5, GeForce GTX590, Win7 Pro 64bit
Re: Audio Out of Synchronization
Mon May 20, 2013 6:50 am
Are you recording to the same HDD as the game and OS is installed on? This is not recommended, and can cause problems such as this. You should have a separate HDD as your target recording location.
Try without the seperate audio track to see if the same problem persists.
Lightning-kun
Mon May 20, 2013 2:21 pm
No, I'm recording to external HDD. And I've tried without separated tracks.
Tue May 21, 2013 3:59 pm
Lightning-kun wrote:No, I'm recording to external HDD. And I've tried without separated tracks.
How is your external HDD plugged?
Lightning-kun
Tue May 21, 2013 6:40 pm
With USB 3.0
