sc2142
PC Specification: Windows 7
Wont record
Sat May 18, 2013 1:17 pm
For some reason Action! Wont record when i have d3d9.dll in the games dir that i want to record, Action! Will just crash the game, it wont even launch, Can you please fix this issue, or is there a way i can fix it without removing the d3d9.dll?
Re: Wont record
Wed May 22, 2013 10:56 am
d3d9.dll is a system library which Action! only use. Try re-installing your DirectX.
DJJoeJoe
PC Specification: Windows 8 64bit | CPU Q9300 | GPU 560
Re: Wont record
Wed May 22, 2013 11:18 pm
He's most likely talking about injection methods that use that .dll specifically. Methods like ENB or SMAA/FXAA and that sort of stuff, make Action unhappy often especially SMAA.
