mordax
PC Specification: fx8350, win7 gtx690 SLI ..etc
can't export more than 1 file at a time ....??!
Sun May 19, 2013 8:44 am
Hi. i've been using Action! for about a month now and i like it more than famous Fraps and Dxtory, however it has huge downside .. i can't find a way to export all videos at once. i have like 50 recordings ... and doing it one by one, means i have to just SIT behind pc for 1-2 hours doing nothing .. but just exporting, this is too lame.
or am i simply missing something and there is way of exporting all at once?
I would work with RAW files, but camtasia can't open RAW files on some reason, it opens Fraps raw recordings fine, but not Action! ones ... so my only hope is to export.
if there is no such feature, how about adding one ASAP? because its extremely important... i can't even believe anyone would make a program and not have a mass exporter/converter .. eh
Re: can't export more than 1 file at a time ....??!
Wed May 22, 2013 10:48 am
Future plans include batch exporting, but currently there's no release date for this feature.
mordax
Sun May 26, 2013 3:25 am
i hope its soon, because i like the recorder and don't want to go back using fraps or dxtory.
can you suggest a video converter that can handle these files and supports CUDA? something that would output similar quality to HIGH profile of action! ?
offtopic - action! really needs automatic file split during recording, another downside. i hope you guys improve it a lot.
Tue May 28, 2013 12:39 pm
Do you experience any errors while trying to import your video into Camtasia Studio? We tested this software and our videos was successfully imported.
WebMaximus
PC Specification: Intel Core i7 2700K, GTX 680, Win7 x64
Wed Jul 24, 2013 5:00 pm
I was just about to ask about this myself, I too really hope you'll implement a feature in the near future where you're able to select more than one file at a time for export.
Please put this on your to-do list for next update/version, would be much appreciated !!
WebMaximus
Thu Sep 18, 2014 6:17 pm
Any news when a batch export feature will see the light?
Montago
Tue Nov 10, 2015 11:09 am
will this feature come eventually ??
