majik
PC Specification: 2600K, HD5870, Windows 7 Professional
Recommended settings
Sun May 26, 2013 8:47 am
Hi all,
I bought Action! last week and only got around to it today. I tried everything high and recorded a dota 2 match however it was taken forever to load in Action! as the file was huge (28gb). SO I turned down the settings to 1080p 30fps on the main page and on the video recording setting it's set at Normal and the input range is 0-255 but it's still pretty large.
So I am new to this recording scene (if you would call it that :) ) and so my question is it normal for the file to be really large because I knew in Fraps that the videos captured were raw and uncompressed but I thought Action! was different? Even if this is normal, what are the export settings I should use to get a nice clear enough video (probably 720p) without the huge file size or do I need to do post processing with another third party software?
Thanks in advance!
Re: Recommended settings
Tue May 28, 2013 12:36 pm
Yes, the raw files are always bigger because they are usually not compressed or the compression is really small. If you would like to record low file size videos you should try our real-time MP4 recording.
Users browsing this forum: leopeck and 26 guests
