skpManiac
PC Specification: Intel i9, 3080Ti, Win 10 Pro x64 64Gb
Audio Problems with Asus Xonar
Fri May 31, 2013 11:03 pm
Hi there,
before the last 2 updates I had no issues recording Audio on my videos, now I have loads of issues :/
I have an Asus Xonar and I have disabled ALL none used speaker configs in Audio Settings so the only ones that show in Action are (4-Asus Xonar) and the DEFAULT - if I record in normal mode its ok, but as soon as I go full screen I lose Audio on the recordings - this is most obvious while using the Steam App
Can you please help?
BTW, ALL drivers, Bios's etc are latest versions, OS is Windows 7 x64
This is the Spec of the PC in question:
Operating System
Microsoft Windows 7 Enterprise 64-bit SP1
CPU
Intel Core i7 3770K @ 3.50GHz 44 °C
Ivy Bridge 22nm Technology
RAM
16.0GB Dual-Channel DDR3
Motherboard
Gigabyte Technology Co., Ltd. Z77X-UP4 TH (Intel Core i7-3770K CPU @ 3.50GHz) 28 °C
Graphics
LG TV (1600x900@59Hz)
2048MB GeForce GTX 660 Ti (Gigabyte) 34 °C
Hard Drives
466GB Western Digital WDC WD5000AZRX-00A8LB0 (SATA) 27 °C
1863GB Western Digital WDC WD20EARS-00S8B1 (SATA) 30 °C
1863GB Seagate ST2000DL003-9VT166 (SATA) 34 °C
2795GB Seagate ST3000DM 001-9YN166 SCSI Disk Device (SATA) 31 °C
1863GB Western Digital WDC WD20 EARS-00S8B1 SCSI Disk Device (SATA) 31 °C
Optical Drives
HL-DT-ST BD-RE GGW-H20L
ELBY CLONEDRIVE SCSI CdRom Device
ATAPI iHAS224 B
Audio
ASUS Xonar D2 Audio Device
Re: Audio Problems with Asus Xonar
Sat Jun 01, 2013 1:31 pm
Do you use any special effects on your Asus Xonar?
skpManiac
Sat Jun 01, 2013 5:12 pm
No, its all set at standard sounds :) I am a bit of an Audiophile
I have tried turning Multi Channel AR on/off
Tue Jun 04, 2013 5:17 pm
There's always something wrong with the Xonars... Is it possible that you could upload a screenshot of your Xonar panel?
skpManiac
Tue Jun 04, 2013 9:23 pm
You cant just blame the sound card when it worked great when I first bought the app, nothing in my system has changed. The app has had 2 updates since, I went a couple of weeks without using it and now it wont record audio in full screen.
If I run media player it will record the audio, but if I run Steam for example, in full screen the audio is missing.
Neither DEFAULT or the XONAR here makes a difference
Xonar 3.JPG (34.66 KiB) Viewed 20513 times
I have all other outputs disabled so Action! doesn't list them
Xonar 2.JPG (40.88 KiB) Viewed 20513 times
The XONAR control panel
Xonar 1.JPG (47.73 KiB) Viewed 20513 times
skpManiac
Tue Jun 04, 2013 10:13 pm
ok, I have sat here and gone through all configs with the settings, if I drop my speakers to 5.1 it records audio fine, so seems to be a compatibility issue between 7.1 and Action!
This is my current set up and Action! records - so until you can resolve it (hopefully you can) I will have to alter my settings to 5.1 surround.
Steve
Xonar 4.JPG (44.48 KiB) Viewed 20509 times
lemonade
PC Specification: i5-3570k, GTX 560 Ti, Windows 7 64-bit
Fri Jun 07, 2013 2:57 am
Is your listening device tied to a different DAC or Amp? If not, you don't need SPDIF Out on. That's only necessary if you're... you know... using an SPDIF interface.
Also, Analog Out represents the amount of channels your listening device has. If you have an ACTUAL 5.1 setup with speakers, that's fine. If you're using stereo headphones, you should be using Headphone mode.
Audio Channel represents what goes in. For example, to utilize Dolby, it requires more input channels. As such, increase the audio channels accordingly.
From what I see, you're UPMIXING sound, which can't be very good, and maybe that's your problem! :x
skpManiac
Fri Jun 07, 2013 5:00 pm
Yes, it is linked to a 7.1 Amp, so less of the sarcasm would be appreciated because, you know, I AM using an SPDIF interface!
Isn't this a bit obvious? It has ALWAYS been set to 7.1 because my amp is 7.1 but now I have to drop it to 5.1 to record through Action! - I am not sure what has changed other than the software.
The whole point of me buying a DTS/7.1 card is top UPSCALE 2 channel and 5.1 audio to 7.1 as very little is actually recorded in 7.1 - I don't see why upscaling the audio is my problem when Action records in normal screen mode but not in FULL SCREEN? The audio drivers do not change when I switch to full screen.
I did try to upload an MP4 of my screen as it flicks to FULL SCREEN and Action! stops recording audio
It's a bit odd :/
