Marshii
PC Specification: Windows 7
Action process running, but application fails to start
Tue Jun 04, 2013 12:12 pm
This is a relatively new problem I've experienced with Action, it has been running absolutely fine until today when I tried to open it. Instead of starting as it would have done on any other occasion it simply doesn't. So I check the processes in task manager and the process is running fine. What I have noticed though is that there are 2 other action processes running at the same time. I am not sure whether these used to run or whether these are new appearances but these are the names of the processes in order of memory usage;
Action.exe *32
Action_x64.bin
Action_x86.bin *32
I have no clue why there would be 3 processes. All I know is that I am running windows 7, action is allowed through my firewall etc and has been running fine on the same computer settings since early March, yet all of a sudden it is deciding to give me a hard time.
Any help would be greatly appreciated.
Many thanks.
Marshii
Re: Action process running, but application fails to start
Tue Jun 04, 2013 12:44 pm
Well I have now found it is not a case of the application failing to start, it is the window failing to open as I still have the overlay in game.
Ahhhh, this is too strange...
triskele10
PC Specification: i5-2500k/gtx660ti/win8x64
Tue Jun 04, 2013 1:08 pm
I just got an Windows update, .NET framework 4.5 and I have the interface back on my desk.
Tue Jun 04, 2013 5:07 pm
It was caused by some connections issues. It's already fixed.
SimBar95
PC Specification: i5 2500, Gtx 550ti
Mon Jun 17, 2013 4:50 pm
I have the same problem! I can't run Action! If I try, it appears for 1 second and then disappears. In the Task Manager there are theese processes Action.exe *32
Action_x64.bin
Action_x86.bin *32
But they disappear with the program.
Help
Thanks you
