eR1k
PC Specification: 3770k, GTX 680, W7, 4x SSD
Intel Quick Sync - big fps drop when recording
Wed Jun 05, 2013 6:47 pm
Hi everyone,
I've read numerous posts concerning the fact that recording with Intel Quick Sync only leads to a minor decrease in performance. I find this really awesome, because a dedicated capture card, such as the Live Gamer HD, is useless to me due to the resolution of my monitor (2560x1600).
However, I do experience a great drop in FPS; in Guild Wars 2 my FPS drops from 98 to 57 FPS. Guild Wars 2 is a very CPU bound game, so I also ran a test using Crysis 2 (GPU heavy game) and again my FPS drops significantly from 113 to 73 FPS while recording. I'm recording at 1080p 30fps.
I have tested recording to a 8GB ramdisk instead of a SSD, but the performance decrease remains identical. Also, the performance when recording to AVI in comparisson to IQS is identical.
I'm sure the settings I have used are correct. The two clips below show the actual ingame drop in FPS while recording; the first clip shows Intel Quick Sync was selected.
http://youtu.be/Zn67jk2Nj5g
http://youtu.be/86VfGlQVgR8
My specs are:
Intel i7 3770k at 5.2Ghz (phase change cooling)
16 GB ram at 2400Mhz
Intel HD 4000 running at 1700Mhz.
MSI GTX 680 Lightning
Asus Maximus Gene V
All my drivers are up to date as well, including the HD 4000 drivers. All files are recorded on a Samsung 840 pro SSD.
Choosing AVI over IQS only yields larger file sizes, the actual ingame performance (i.e. FPS drop) for AVI and IQS are identical. I expected using IQS instead of AVI would yield better ingame performance. Is my assumption incorrect? Is the FPS drop that occurs during recording with Intel Quick Sync (40% drop in FPS) the way it should be, or should the performance be better than the performance I'm getting now?
evolution
PC Specification: 3770K, ASUS GTX670 Direct CU II, win7 64
Re: Intel Quick Sync - big fps drop when recording
Sat Jun 08, 2013 3:59 pm
dude mine pc is almost same ;)
dammit friends using i5 3570k processor, video is smooth as butter..
but i7 3770k lag ? what is wrong ? we need patch for mirillis action ! I do not pay money for something dat not working properly
eR1k
Sun Jun 09, 2013 7:47 am
Hey Evolution, thanks for your reply. The video is actually smooth as butter, no problem there. My post is more about whether a 40% FPS drop ingame, once the record button is pressed, is normal. I expected only an insignificant (e.g. 10%) FPS drop due to the hardware acceleration by IQS. Maybe my expectations are too optimistic :D
YouTuber
PC Specification: i5
Sun Jun 09, 2013 3:06 pm
I get massive drops in fps in arma 2 when I set recording to 30fps, when I increase the fps to 60 when recording 1080p I get an increase back to 60 in game however lots of studdering issues and I have lost some good footage this way.
Mon Jun 10, 2013 9:04 am
Could you guys upload your videos so we can see the drops?
eR1k
Tue Jun 11, 2013 10:51 pm
Hi Radi, the links to my videos are in the starting post. See the purple MSI afterburner FPS indicator, it clearly shows a 40% drop when I press the record button.
I found this review of Mirillis versus competitors on YouTube. It's very informative, because it shows that IQS and AVI recording both lead to identical framerates ingame. Radi, I thought that IQS (hardware rendering) in comparisson with AVI (software rendering) would lead to better performance and not result in identical performance?
http://www.youtube.com/watch?v=BvD0Sz3AhAU
Montago
Sat Jul 06, 2013 4:33 pm
Please read and try what I wrote in this thread..
Also make sure that HyperFormance is disabled..
http://forum.mirillis.com/viewtopic.php?f=36&t=28847
