frontgunner
PC Specification: windows 7
Youtube Upload Failed to Convert?
Thu Jun 13, 2013 2:28 am
So I recorded a video using Action! and directly uploaded it to youtube using the default settings. First it would say it uploaded but when i check the video on youtube it says something likes Failed to Convert. Other times I upload it and it cuts my video down time wise. I tried to upload a 19 min 720 video and it made it around 30 seconds...Please if anyone knows how to fix this I need to know asap. I mean I cant use Mirillis' Action! at all to upload to youtube because none of it works, and is kinda a pointless feature if I cant use it. So if anyone can help that would be awesome thanks.
Re: Youtube Upload Failed to Convert?
Tue Jun 18, 2013 6:38 pm
Do you use hardware acceleration for your video exporting?
Sondai
PC Specification: AMD 8350FX, NVIDIA 460 v 2, 4MB RAM
Sat Jun 22, 2013 11:20 pm
Thanks Radi. I had the same problem, came here to post about it and just tried again with HD acceleration off and it works fine.
Users browsing this forum: No registered users and 47 guests
