Giles121
PC Specification: Intel Core i3 Radeon HD 5230
Problem With Action
Thu Jun 13, 2013 11:50 am
When I Have Action In Game Recording Mode I Cant Launch GTAIV It Come Up With This
I Have Th Following .ddl In My Game Folder d3d9.ddl And When I Take It Out The Game Launches With Action On Game Recording Mode So Im Wondering Does It Use This .ddl And Is They A Fix I Need This dd. In My Game For A Graphic ENB
Re: Problem With Action
Thu Jun 13, 2013 4:53 pm
What's SecuROM?
AlanDavison
Thu Jun 13, 2013 6:54 pm
I'm going to guess that SecuROM, being the overly-paranoid DRM that it is doesn't like whatever hooks Action! uses to capture whatever graphics buffers it does, and promptly crashes and burns because of it.
If the game launches properly without the in-game recording mode set, then I'd hazard a guess it's a bug in SecuROM crashing because of Action!'s hooks. Unfortunately, I don't have GTA 4 installed right now, or I would test it myself.
Giles121
Fri Jun 14, 2013 12:29 pm
Thanks For Replys, But I Edited Some Of Mirillis Config And It Works Now Perfectly :), Thanks For replys Thow And Securom Is Just The Launcher Of GTAIV
I'd Say To Anyone To Get This Game Recorder Tool Is Perfect !! No Lag In Game Play Recording And Files Dont Get Too Big, I Thank The Makers Of This Software
Tue Jun 18, 2013 6:35 pm
Great to hear that your issue is solved. Could you post what exactly you have changed for future users that may experience similar issues?
