tolin
Audio problems with DVB-T
Fri May 07, 2010 9:45 am
Hi.
Oor local (Israel) DVB-T channels configs are:
Video: h.264 (mpeg4)
Audio: AAC + V2
When I play the channel with your program, the audio lags (video is before the audio) and interrupts (every 2 seconds there is no audio)
adam777
Re: Audio problems with DVB-T
Fri May 07, 2010 12:39 pm
Hi tolin,
I've seen this behavior as well, until a permanent solution is found, I suggest you switch to another channel, let it load, and return to the original one, it usually sorts things out. If it hasn't just repeat the thing again :D
tolin
Fri May 07, 2010 1:13 pm
what do you mean switch to another channel?
All channels have the same config.
adam777
Fri May 07, 2010 2:56 pm
channel 2 -> channel 10 -> channel 2
