Shory0
PC Specification: i7 3770K / 8Go / GTX 670 / Win7 64
More cpu usage Action!
Mon Jun 24, 2013 2:27 pm
I would like that Action! use more resources than what it makes, to increase the performances. Is there a means to make it ?
I use processor in 4 cores, so if there was a means that it uses more cores than at present.
Thank you very much
Re: More cpu usage Action!
Tue Jun 25, 2013 10:07 am
Action! is optimized to use as low resources as it can so you can't even feel it working while you are recording your videos.
