flashmp3
Intel Quick Sync AVI
Tue Jun 25, 2013 1:03 pm
Hi
Is Action! going to support quicksync usage with avi recording ? I'm asking that because i edit my recordings with other software and they all don't like the mp4 produced by Action!. So i have to use AVI but would like to take benefit from intel quicl sync technology
Re: Intel Quick Sync AVI
Wed Jun 26, 2013 1:57 pm
There's no such thing like Intel Quick Sync AVI.
flashmp3
Fri Jun 28, 2013 10:15 am
I didn't really understand what you mean. Sorry i'm french. Are you saying quicksync can be used only with mp4 files ? In that case is there a way to produce video that are editable without problems after ?
Fri Jun 28, 2013 11:05 am
flashmp3 wrote:I didn't really understand what you mean. Sorry i'm french. Are you saying quicksync can be used only with mp4 files ? In that case is there a way to produce video that are editable without problems after ?
Intel Quick Technology is hardware video encoding and decoding technology You can read more about IQS here http://www.intel.com/content/www/fr/fr/ ... neral.html
What problems do you experience with editing MP4 files?
flashmp3
Fri Jun 28, 2013 5:00 pm
it doesn't recognize the file well with camtasia and magix 5
Cauptain
Contact: ICQ
Sat Jun 29, 2013 6:28 am
flashmp3 wrote:it doesn't recognize the file well with camtasia and magix 5
Hi flashmp3,
Try this solution
Its work for various containers (M2TS, MP4, MKV...)
Try & reply.
Claudio
flashmp3
Sat Jun 29, 2013 10:09 am
Hi flashmp3,
Try this solution
Try & reply.
Claudio
Thank you very much i ll definitely try it !
