starwars793
PC Specification: Windows 8
Sound is gone.
Wed Jun 26, 2013 6:50 pm
I have been using the trial version of Action! and whenever I would record, the sound would be there and perfect. Recently, my headphones have been giving out on the sound. Now whenever I record, it doesn't capture the sound. Are the headphones the reason of it messing up?
Re: Sound is gone.
Thu Jun 27, 2013 11:10 am
How are your headphones connected to your PC? Is any sound picked up?
starwars793
Re: Sound is gone.
Thu Jun 27, 2013 7:08 pm
My headphones are connected via USB and sound port. Sound is picked up but I have to mess with the wire.
Re: Sound is gone.
Fri Jun 28, 2013 11:04 am
It may be related to the USB headphones. Do you have any possibility to try other sound device like speakers or different headphones plugged via line-in and mic-in?
starwars793
Re: Sound is gone.
Fri Jun 28, 2013 4:52 pm
Yes, I have just tried that. Turns out because of my headphones losing sound, Action! stopped recognizing those headphones. I am now able to record the sound. Thanks for the help.
