AppleDashu
PC Specification: FX Vishera x8 - Nvidia GTX560 - Win8
Action problems on Windows 8.
Mon Jul 01, 2013 10:48 pm
Hi, i bought Action Mirillis, and i have problems on Windows 8, when i open Action, the process appears, but the program never opens, please help me u-u
Image:
Re: Action problems on Windows 8.
Tue Jul 02, 2013 9:17 am
Is this Windows 8 or Windows 8.1 preview?
AppleDashu
Tue Jul 02, 2013 8:37 pm
Windows 8 Pro.
Wed Jul 03, 2013 7:55 am
Please contact our support team directly via support@mirillis.com.
AppleDashu
Sat Jul 06, 2013 1:47 am
Still waiting for a solution...
AppleDashu
Tue Jul 09, 2013 2:21 am
And still waiting...
AppleDashu
Wed Jul 10, 2013 10:11 am
9 Days waiting... and nothing.
Cauptain
Contact: ICQ
Thu Jul 11, 2013 9:18 am
Hi AppleDashu.
Windows 8 64bits?
After run action.exe, its show on task manager, correct?
Make this:
- Uninstall the Mirillis Action.
- Press Windows key + R, type APPDATA and ENTER.
- Go to AppData\Local and delete Mirillis folder.
- Go to AppData\Roaming and delete Mirillis folder.
- Press Windows key + R, type REGEDIT and ENTER.
- Find HKEY_CURRENT_USER\Software\ and delete Mirillis folder.
- Download CCLEANER and run REGISTRY. After completion push FIX SELECTED.
- Repeat this until show NO ERROS FOUND dialog box.
- Reboot Your PC and install Action! in TRIAL mode, not use your key.
- Remember uptodate drivers/softwares: Motherboard chipset, videocard, soundcard and DirectX 9 (got DX 9 web setup install)
Try and reply if change anything.
Claudio
