WebMaximus
PC Specification: Intel Core i7 2700K, GTX 680, Win7 x64
How to disable some of the default hotkeys?
Tue Jul 02, 2013 12:31 am
Just downloaded the trial version of Action! and it's looking really good so far!
One quick question though which I haven't been able to find an answer to looking through the documentation, how can I disable the hotkeys for Record Audio, Benchmarking and Capture Screenshots (F10, F11 and F12)?
I was able to clear all other hotkeys by simply removing the check next to them but doesn't seem to work for the above mentioned hotkeys?
Re: How to disable some of the default hotkeys?
Tue Jul 02, 2013 9:15 am
WebMaximus wrote:Just downloaded the trial version of Action! and it's looking really good so far!
Unfortunately main hotkeys (first four) cannot be disabled.
WebMaximus
Tue Jul 02, 2013 9:33 am
Wow...that's a bit weird :o
May I ask why and is this something you'll address in a future update?
Reason I ask is I'll be using Action! (or whatever software I end up choosing) to capture flights in MS Flight Simulator X which already uses pretty much all keyboard shotcuts you could possible think of and a combination of them so you don't really want to "waste" any hotkeys on features/software you don't use.
WebMaximus
Sun Aug 04, 2013 2:04 pm
Just installed the latest update and noticed you still can't disable the first four shortcuts. I was kind of hoping you would have been able to fix this and I imagine it would be a fairly easy thing for you to do...simply letting users decide if they want these shortcuts active in the same way as with all other shortcuts...?
Would really appreciate if you could address this in next update.
Mon Aug 05, 2013 12:27 pm
At this moment this cannot be done due technical reasons.
WebMaximus
Mon Aug 05, 2013 2:54 pm
Ok, too bad and must admit I'm a bit surprised since it appears as a quite simple thing but then I'm not a programmer so I wouldn't know.
Aleksey
PC Specification: amd 2700x, 2060super, win 10
Tue Mar 10, 2020 8:53 pm
I stumbled into the same problem, but found an easy solution.
you can map them to something like ctrl+alt+shift+\
then they won't interefere.
