GlitchyV2
PC Specification: Windows 7 Ultimate 64-Bit
Weird echo in recording?
Tue Jul 02, 2013 7:23 pm
Hello, my name is Glitchy, and i'm a starting youtuber!
I have to say, i absolutely love Action!
It is most likely the best recording software ever :D
But... Today i was recording my walkthrough of Deadpool, and i noticed a weird echo in the recording!
I decided to upload it anyway, but i want to fix it as soon as possible!
Here is the video: http://www.youtube.com/watch?v=APT4VeFK3xo
Does anyone know how to fix this?
Thanks -Glitchy
Montago
Re: Weird echo in recording?
Sat Jul 06, 2013 3:29 pm
In your audio settings you should check if you have enabled multiple inputs..
Are you using any input ports by chance ?
My x-fi onboard card will make echo if I do not mute one of the 2 input ports...
