Montago
AMD 13.4 + MVP 2.1.226 + Intel 15.31.9.64.3165 = Fail
Wed Jul 03, 2013 8:07 pm
I've reinstalled my computer today and now Mirillis Action doesn't work anymore :-(
I've installed the latest of everything:
- Mirillis Action: 1.14.3.0
- Intel 15.31.9.64.3165 (released 10 May-2013)
- VirtuMVP 2.1.226 (released 24 June 2013)
- AMD 13.4 (released 24 april 2013)
computer is fully updated
When recording, the color changes to red and the framerate goes down to 30.. but the MP4 file is 0 KB and the game crashes when stopping the recording :o :shock: :cry:
HELP ?
RazrBit
PC Specification: I7-3770K, HD6950, 8 x64, 8GB
Re: AMD 13.4 + MVP 2.1.226 + Intel 15.31.9.64.3165 = Fail
Fri Jul 05, 2013 9:00 pm
The 1st gen VirtuMVP never worked with Action!, at least for me, while 2nd does without any problems and didn't have not a single problem with any game. Excluding game launchers, some don't start when VituMVP is enabled. Assuming you have created a profile for Action!.
Montago
Fri Jul 05, 2013 11:17 pm
before reformatting, it worked perfectly !
well.. I downgraded the Drivers:
MVP -> 2.1.224
Intel -> 15.31.3.64.3071
and now it records again :-/ ... i bet the problem was Intel drivers, coz the difference in the MVP drivers are negligible (gui updates)
RazrBit :
There no real difference between MVP and MVP2 .. other than the fancy GUI.
the MVP program enables features that are already on the motherboard...
