P.J
Problem with "Zoom" Display format
Sun Jul 07, 2013 8:12 pm
I have noticed that Splash can't Zoom on SD H.264 videos and just Stretch them
Code: Select all
General
Format                                   : MPEG-4
Format profile                           : Base Media
Codec ID                                 : isom
File size                                : 75.5 MiB
Duration                                 : 3mn 14s
Overall bit rate mode                    : Variable
Overall bit rate                         : 3 255 Kbps
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : Main@L3.0
Format settings, CABAC                   : No
Format settings, ReFrames                : 2 frames
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 3mn 14s
Bit rate                                 : 3 122 Kbps
Maximum bit rate                         : 6 573 Kbps
Width                                    : 720 pixels
Height                                   : 576 pixels
Display aspect ratio                     : 4:3
Frame rate mode                          : Constant
Frame rate                               : 25.000 fps
Standard                                 : PAL
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.301
Stream size                              : 72.4 MiB (96%)
Language                                 : English
Encoded date                             : UTC 2011-01-16 17:17:35
Tagged date                              : UTC 2011-01-16 17:17:38
Color primaries                          : BT.601 NTSC
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.601
Audio
Format                                   : AAC
Format/Info                              : Advanced Audio Codec
Format profile                           : LC
Codec ID                                 : 40
Duration                                 : 3mn 14s
Bit rate mode                            : Variable
Bit rate                                 : 129 Kbps
Maximum bit rate                         : 148 Kbps
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 48.0 KHz
Compression mode                         : Lossy
Stream size                              : 3.00 MiB (4%)
Language                                 : English
Encoded date                             : UTC 2011-01-16 17:17:37
