Snozzle
PC Specification: gtx 670
Can't export, options greyed out
Mon Jul 08, 2013 11:07 am
Sorry I might be missing something obvious here, but I can't seem to get the export options to work at all.
The export icons down the bottom (the arrow, youtube, facebook) are all greyed out.
If I right click on a video then the 'export' option is greyed out.
Running 1.14.3
See the attached picture for an example
Anyone can point me in the right direction?
Thanks
export greyed out
Re: Can't export, options greyed out
Tue Jul 09, 2013 4:02 pm
Probably you are trying to export MP4 file which is impossible.
Snozzle
Tue Jul 09, 2013 8:22 pm
Thanks, yes they were mp4 files.
Could you let me know which file types are supported?
Is there any way I can encode to h.264 (using quicksync), into a file format that Action allows me to upload?
If not, that's fine, I can still upload those mp4's to youtube manually through their website, it would just be nice to do it all in one place.
Thanks again for your help!
Snozzle
Tue Jul 09, 2013 10:05 pm
Wait I found some more information on it:
First, Action! will export/convert your gameplay or desktop recording to MP4 format. This will reduce video recording file size and allow faster uploading. Please note that raw Action! video recordings cannot be uploaded to YouTube directly as YouTube does not support FICV video codec used in raw AVI video recordings.
That sounds like Youtube only supports mp4?
