StarscreamUK
PC Specification: i72600k@4.2ghz/win 8/2x 7950
Big performance drop
Wed Jul 10, 2013 7:36 pm
Hi, not sure if it's something I've missed along the way.
Action great software, running bf3 @ 1080 gave constant smooth 60fps
that was on 1 x 7950
I now have 2 running in crossfire
my bf3 framerates have risen from 92 to around 130fps
but recording in action has taken a big hit, dropping as low as 32fps and averaging around 54
any ideas anyone?
Re: Big performance drop
Thu Jul 11, 2013 3:42 pm
It's probably related to your crossfire card. Could you check if you use one card only you also get drops?
StarscreamUK
Thu Jul 11, 2013 6:29 pm
with 1 card no drops, just a lower framerate when not recording.
there must be a workaround for this as its a pain having to power down remove a card to record then reverse when not wanting to record
daniel44
Fri Jul 12, 2013 1:39 pm
did you try and check other recording settings to see if the results are different?
btw how did you get 92 fps?
i assume that your are playing on ultra.
how can you get that amount of fps from that card?
somethimes i gow below 50 when playing on 1920X1080 on ultra settings.
StarscreamUK
Mon Jul 22, 2013 9:03 pm
daniel44 wrote:did you try and check other recording settings to see if the results are different?
I'm running:
I7 2600k @ 4.3ghz
16gb ram
2 x 7950 xfire
yes ultra settings, but I lower the AA, "jaggies" arent a helluva problem @ 1920x1080, not like they used to be back in the 1024 x768 days
