sweduck75
Greenscreen for cam on it's way?
Thu Jul 18, 2013 3:00 pm
Greetings sirs!
Action! is totally awesome in so many ways but I'm afraid I don't like being boxed in when using facecam. To spare my weak li'll computer during recording games I've thought about grabbing a capturecard allthough I just remembered: Didn't someone say that some sort of chromakey-feature is about to hit Action?
So, that is my question: Will there still be a chromakey-feature for Action?
and if so:
About when do you think that version will be released?
Take care and enjoy your summer!
/Ducky
Montago
Re: Greenscreen for cam on it's way?
Thu Jul 18, 2013 7:18 pm
couldn't you simply record your webcam next to Action, using the software that support chroma key... then afterwords edit yourself in ?
the thing you request sounds very specific - so you shouldn't get your hopes up high...
sweduck75
Thu Jul 18, 2013 7:36 pm
I usually do that but my computer isn't that good so I get lower Fps. Mirillis have talked about chromakey in the past. I just wanted the updated status, if it's still a go or if it's been cancelled.
Fri Jul 19, 2013 9:24 am
We are planning to expand Webcam functionality for more features including chroma key, but currently there's no specific release date for this kind of functionality.
sweduck75
Wed Jan 29, 2014 12:29 pm
Hey team! :)
It's been about half a year or so, thought I'd check in.
Any updates on above matter with chroma-key / greenscreen?
Hope you had a great winter!
/Ducky
SapioiT
PC Specification: W7, Core2Duo, AMD Ati His, etc.
Wed Feb 12, 2014 10:40 pm
I'm looking into it, too... It will be a good addition to this great software! And, maybe, like an option to add borders, since we're already here... it will be a bit easier, in fact...
Horzy
PC Specification: i7 4770k, ASUS GTX 770, 16GB RAM, W8.1
Tue Jan 20, 2015 7:03 pm
Hi Guys! I understand that I'm adding comments in extremely old topic but is there any update on this one. This must be the only option which I am missing at the moment in Action! I understand that you are probably unable to give any time frame for this but are you looking in to it at all?
zhker
PC Specification: Win 10, i7 3770, GTX 1080, 16gb DDR3
Thu Jun 16, 2016 10:32 pm
Hi!
And I'd like to ask the same question also... As I see, this post updates once a year by a user... and still no greenscreen. Any news on this?
