robertojun
PC Specification: AMD FX 8320, Nvidea GTX 550 Ti, Windows7
I Can't recor my voice when i choose "Record microphone..."
Fri Jul 19, 2013 9:14 pm
I can't record my voice when I mark the option "Record microphone into separate audio track (AVI)", I already checked:
I am recording with AVI mode on.
My microphone are regular sound volume
I can hear my voice in the record only if I UNCHECK the "Record microphone into separate audio track (AVI)" box
***I use the Corsair 1500 and he have a USB instead of a regular green/pink conector
How I can solve that?
Re: I Can't recor my voice when i choose "Record microphone.
Mon Jul 22, 2013 5:13 pm
One thing you should know about recording microphone into separate audio track feature is that when you are playing back your video in Action! player you will hear only one audio track at the same time. Action! player does not mix them in real time. You can switch between active audio track with "A" hotkey.
robertojun
Mon Jul 22, 2013 7:07 pm
thank you,
Somehow I feel me so dumb right now :P
