smokemist_xi
PC Specification: gtx 670ftw sli, i53570k 4.4ghz, 16gb ram
push to talk key huge issue
Mon Jul 22, 2013 9:33 pm
okay here is the problem. when you are pressing PTT key only it records your voice just fine. but if you are pressing shift alt or ctrl while pressing PTT button it is not recording what is up with that?
StarscreamUK
PC Specification: i72600k@4.2ghz/win 8/2x 7950
Re: push to talk key huge issue
Sun Aug 04, 2013 7:50 am
thats because you are then pressing an entirely new hotkey combination
