MrStevo
PC Specification: AMD 8350, GTX 670, 16GB, Win8.1
Saving Capture
Sat Jul 27, 2013 5:38 am
Just bought it and installed, first capture went well, i changed the default save location and now it says "please select diff rec folder". Ive tried many places on my HDD as well with the default location and i cant get passed this error. I even uninstalled and reinstalled. I cant use this at all now seeing that i cannot find a place to save.
Please and Thanks
Re: Saving Capture
Mon Jul 29, 2013 2:10 pm
Due technical issues your output folder on Windows 8 must be located on the same drive where your Windows is installed.
