JuicyCrafter
PC Specification: 4 i5-2320 3.00GHz GT 610 W.HP 16GB
Action! Webcam Problem
Sat Jul 27, 2013 9:02 pm
I recently bought the full version of Action! and was looking forward to the webcam feature it had to offer. But to my sadness, When I selected my webcam and selected always record, It did not show the recorded webcam in the video. The light on the webcam was on, Indicating that it is being used, but the video never showed up. When I selected preview in the webcam options, It showed up just fine there. I followed the tutorials on the website but no matter what I tried it did not work! :evil: The webcam is working great in every other program I have but just Action! Any help is very welcomed
- Thanks!
Re: Action! Webcam Problem
Mon Jul 29, 2013 2:09 pm
Does it work with MP4?
JuicyCrafter
Tue Jul 30, 2013 1:54 am
Yes it does but it is very low res and would like to use avi. Any way around it?
Tue Jul 30, 2013 7:01 am
Try this:
1. Uninstall Action!
3. Remove Action! catalog.
4. Reboot your PC.
5. Do not run any additional applications. Turn off all aplications that may use video codecs (example: Windows Media Player).
6. Install Action! again. Make sure that your installer file comes from official website - www.mirillis.com.
CommMolander
PC Specification: Windows 8
Thu Jun 04, 2015 7:40 pm
I followed the steps and it worked, but the next day it went vback to having the issue. how to i keep the webcam working without constantly uninstalling Action?
Mon Jun 08, 2015 5:45 pm
CommMolander wrote:I followed the steps and it worked, but the next day it went vback to having the issue. how to i keep the webcam working without constantly uninstalling Action?
If the issue is reoccurring then I suspect there is something wrong webcam/system configuration than Action.
CommMolander
Sun Jun 14, 2015 12:13 am
The issue was caused by the curser present during recording feature. in the settings, if its turned off then the webcam will not work properly. if it is turned on (curser will be shown during recording) then the webcam will work properly. (Refer to https://www.youtube.com/watch?v=U7aNeOptGhs) this video showed me how to fix it so yea easy step to take. so yea. hope that helps.
nafela
PC Specification: i7 4790 , gtx 750 ti, win10 version 1607
Thu Aug 18, 2022 8:37 am
me too, i have tried this methode but somtime work and not work,
delete local temp dan windows temp file
uninstall mirillis
delete mirillis registry data
delete all about mirillis in drive c
retsart pc then :
re install ivicam
re install mirillis
start ivcam after connected between mobile and ivcam on pc then start mirillis
open setting privacy and camera set t oallow app using camera
service windows camera set to stop
and the problem was fixed
but the problem happen again :v
and i tried the above metode and its not worked anymore idk why ?? hahha
i tried fresh OS windows 10 installation many time and not work too
