BioAftermath
PC Specification: Window 7
Problems with Action!
Wed Jul 31, 2013 11:41 pm
First, when I try to record gameplay on WaW it crashes on me even when I've tried everything.
Second, when I record Battlefield 3, my frame rate drops a lot and it becomes hard to play and record a good gameplay.
Third, when I do get lucky enough to get a good gameplay, the bit-rate is to high to view smoothly in Sony Vegas 1, and there is no rendering template that I can use to capture full HD (basically, it comes out looking like crap, even though when I play it back in Action!, it looks good). I', starting to feel that this is a bad recording software and that I should start looking for one that doesn't have these problems.
Re: Problems with Action!
Mon Aug 05, 2013 12:40 pm
Do you record Battlefield to the same hard drive where the game is installed and Action! output folder is located?
ericneo
PC Specification: 3770k, 680GTX, win7, 64bit
Tue Aug 06, 2013 12:59 am
BioAftermath what format and size are you recording at?
AVI/MP4/MP4I
480/720/1080
I recently became aware of the Export function in action! which is also basically a video converter.
