Paperclip
PC Specification: Windows 7
Action.exe does not run.
Sat Aug 03, 2013 2:07 pm
Hello. I am using the free trial of Mirillis Action. When I attempt to run Action.exe my mouse makes the loading animation
for a second and then stops. I just looked at my task manager and saw it was already running. I ended the process and
tried again. This time the rectangular black box with Mirillis Action appeared, then disappeared. I am able to run ActionPlayer.exe
My specs : OS Name Microsoft Windows 7 Home Premium
Version 6.1.7601 Service Pack 1 Build 7601
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name -
System Manufacturer HP-Pavilion
System Model VG245AA-ABU p6210uk
System Type x64-based PC
Processor AMD Athlon(tm) II X4 620 Processor, 2600 Mhz, 4 Core(s), 4 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 5.11, 06/10/2009
SMBIOS Version 2.5
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume3
Locale Ireland
Hardware Abstraction Layer Version = "6.1.7601.17514"
User Name -\Administrator
Time Zone GMT Daylight Time
Installed Physical Memory (RAM) 4.00 GB
Total Physical Memory 4.00 GB
Available Physical Memory 1.51 GB
Total Virtual Memory 8.00 GB
Available Virtual Memory 4.87 GB
Page File Space 4.00 GB
Page File C:\pagefile.sys
I would really appreciate any suggestions on how to fix the problem. Maybe it's something simple that I'm missing. Thanks!
Paperclip
Re: Action.exe does not run.
Mon Aug 05, 2013 11:46 am
Don't worry guys. I must thank you for your endless support for the last 2 days offering countless hours worth of solutions. And finally after 2 days I figured it out myself. Thanks Forum! -Topic Closed.-
Mon Aug 05, 2013 12:14 pm
This is only a community support. If you experience any issues always contact our support team directly via support@mirillis.com.
It would be great if you could share how did you solve your issue for future users with similar problem.
