luke1078
PC Specification: AMD Phenom II X4 Sapphire 7970 Windows 7
Action! Not recording full desktop Always adding black sides
Sat Aug 03, 2013 5:27 pm
The Title explains it self :?
And also.. it does not record my game (BF3+Others) in the correct resolution. It adds a black screen on the sides.
I also cannot get the bottom part of my screen recorded as well.
THIS IS HOW IT'S SUPPOSED TO BE
THIS IS NOT HOW IT'S SUSPOSED TO BE
Here are my settings as well.
(Extra INFO) I am also in Cinema zoom 1 on my monitor because the desktop doesn't fit to screen correctly and I tried turning it off and recording again but it still has the same result.
So any help would be great :)
Re: Action! Not recording full desktop Always adding black s
Mon Aug 05, 2013 6:47 am
What is your native screen resolution?
luke1078
Wed Aug 07, 2013 3:59 am
radi wrote:What is your native screen resolution?
It is 1920x1080p
Wed Aug 07, 2013 8:53 am
It must be somehow related to the Cinema Zoom thing you mentioned on your first post. How is this done?
luke1078
Fri Aug 09, 2013 2:21 am
radi wrote:It must be somehow related to the Cinema Zoom thing you mentioned on your first post. How is this done?
I turn on Cinema zoom when Windows 7 will not fit to my monitor.. it's basically scaling it to the dimension of the monitor.
