ROBBOsulsu
PC Specification: Windows 7
Audio Balance Suggestion!
Mon Aug 05, 2013 6:23 pm
Hello there.
Action is a great software and I love it, However I still have a lot of problems with it. The major problem I have is the Audio Balance. I use a Blue Yeti Microphone, Which itself is a very strong and sensitive Microphone. I have spent so long trying to get my audio right, In fact I have probably spent around 8 hours in total setting it up. Yet still I have not got perfect results.
So due to this my suggestion would simply be to include an audio balance tester. Simply press a button to hear varied noise levels alongside your own Mic, or maybe even a stronger and more improved auto balance would be a great help. I know how hard it is to set up perfect audio balance, and with the software being a game recorder audio balance plays a major role in the software. I guarantee you if you manage to include these features the ratings for this software will boost as it is a minor thing many software's miss out on.
Thank you in Advance, And I hope you take my suggestions in mind.
Re: Audio Balance Suggestion!
Tue Aug 06, 2013 7:44 am
Thanks for your suggestion. I've forwarded your message to our developers. They will consider your suggestion.
ROBBOsulsu
Tue Aug 06, 2013 4:48 pm
Thank you so much, It's just its a massive pain that I'm having trouble with, and I'm sure if I'm having trouble with it there are most likely others with the same issue :) Thanks once again!
ROBBOsulsu
Tue Aug 06, 2013 6:57 pm
I'm really having trouble guys, I have been trying to do this all day and I cannot find a setup that gives me clear voiceovers for my gameplay. I have tried changing the mics audio, the physical gain on the mic, the audio balance. I just cannot get it right, I'm not anything special with Audio. Computer hardware sure, but when it comes to audio I have no clue what I'm doing. So if anybody can give me some audio suggestions that would be deeply appreciated. I use a Blue Yeti Microphone on Windows 7 and I wish to record steam games with commentary if that's any use. Thanks :(
Wed Aug 07, 2013 8:35 am
As far as I remember there was a similar issue with Yeti microphone. Please contact our support team directly via support@mirillis.com.
ROBBOsulsu
Wed Aug 07, 2013 9:55 am
Ahh Okay thank you, It's just I've spent so long trying to fix this that I may have to go to another recording software for now. Thing is audio balance is the one feature that pulled me into Action! so much, and i'm sure its the same with many others.
