kamilcz
PC Specification: Intel e6750
Codec Error, please install DivX codec message, how to fix?
Wed Aug 07, 2013 10:34 am
When I try to play a video file in my Splash Player Pro EX I get a “Codec Error, please install DivX codec” message.
In the settings of my Splash player the “Check for updates” is check marked but the player won’t update its self on its own!
1. How can I manually update the Splash player Pro EX without waiting for the product to update automatically?
2. Do I have to download additional codecs manually for DivX video files to play in Splash Player Pro EX?
Thank you for all of your help.
Re: Codec Error, please install DivX codec message, how to f
Wed Aug 07, 2013 11:48 am
DivX codec is required to play some video formats properly.
kamilcz
Wed Aug 07, 2013 12:27 pm
radi wrote:DivX codec is required to play some video formats properly.
Why it then that overview of Splash Player Pro ES quotes that:
You don't need any additional codecs to play the best quality videos now!
As on your webpage;
http://www.mirillis.com/en/products/splashexport.html
If the player does in fact need additional codecs to play certain DivX video files as quoted by you then you as a company should provide support and free download on your website!
Or am I just missing something?
Wed Aug 07, 2013 12:45 pm
As on your webpage;
If we are linking now, you can check Features tab (http://www.mirillis.com/en/products/spl ... tures.html) where's specified that DivX codec is required only for HD videos where software decoding is used. With Hardware Acceleration you don't need to install additional codecs.
qkru45
PC Specification: i5
Wed Feb 03, 2016 12:52 pm
Same problem with me please let me know also
MozartMan
Mon Oct 03, 2016 7:15 pm
Urkle wrote:Where can I download the correct version of DivX?
Try here
http://www.videohelp.com/software/DivX-5
JohnBurchfield
PC Specification: Windows 10
Re: Codec Error, please install DivX codec message, how to fix?
Thu Jun 06, 2019 9:55 am
YES, I TOO FACED the SAME PROBLEM. YES, YOU HAVE TO DOWNLOAD ADDITIONAL CODEX.
