Kopenich
PC Specification: I built it but I dont remember, go away.
Video Format etc.
Fri Aug 09, 2013 3:07 am
They said a while ago, that an update allowed raw footage recorded to be edited in your standard 3rd party programs for video editing.
I've tried time and again, and I don't know how to get the .avi files to work with these programs, only .mp4s raw and exported will work.
Thanks for the help!
Re: Video Format etc.
Fri Aug 09, 2013 6:54 am
What program do you use?
Kopenich
Fri Aug 09, 2013 8:13 am
I switch between Sony Vegas Pro 10 and Adobe Premiere Pro CSS5.5.
Other than that, as expected, it's not even preview-able in standard media players like VLC; Other media players just play it as an audio file when I try to preview a raw video.
Fri Aug 09, 2013 8:48 am
Kopenich wrote:I switch between Sony Vegas Pro 10 and Adobe Premiere Pro CSS5.5.
Both Sony Vegas and Adobe PP should work fine with Action! recordings. As for other video players they probably don't support the FICV video codec.
Kopenich
Fri Aug 09, 2013 9:39 am
Is there some setting I should be changing? I took a quick video showing Adobe PP not accepting the .avi, but recognizing the .mp4, and they are both taken with the current version of Action!
For lack of proper means to do so, I have uploaded the video to youtube:
http://www.youtube.com/watch?v=mnT-kWnkdqk
Is there anything else that can cause this? Does the 3rd party software need an additional codec, or the Action! software need an update?
