Sosuko
PC Specification: Windows 8
Audio Quality Issue After Update
Sat Aug 10, 2013 4:29 pm
So after I updated to the newest version (with the LIVE streaming thing I don't have any use for), my audio quality when recording is pretty bad. I don't know if anyone else has had this issue, but I've tried fiddling with the settings with no results.
Initially after installing action I didn't change any of the default audio settings, so I'm pretty confused as to what is going on, and any help would be appreciated.
Just out of curiosity, is it possible to switch back to an older version of action? As I said, I really have no use for the new additions.
Re: Audio Quality Issue After Update
Mon Aug 12, 2013 4:50 pm
You should try contacting our support team (support@mirillis.com). This is really strange that you find your audio quality worse than before.
