sentinelvdx
PC Specification: i7 2600K, 16GB 2133Mhz, HD7970
[Problem] Steam's Game Overlay Issue with Action! Open
Mon Aug 12, 2013 12:24 am
I'm having this problem:
When I open Action! the Steam game overlay stops working. I mean, I can play, record, everything, but I cannot go to the steam overlay menu by pressing Alt+Shift.
Is there any way to have Steam's Game Overlay and Action! working at the same time?
dimanish
PC Specification: i5-2500k, gtx680, 16GB ram, win 7 sp 1
Re: [Problem] Steam's Game Overlay Issue with Action! Open
Mon Aug 12, 2013 8:04 am
Did you try solution from this post? http://forum.mirillis.com/viewtopic.php?p=40226#p40226
Is it working for you? I have the same problem and solution doesn't help for me...
sentinelvdx
Mon Aug 12, 2013 5:05 pm
dimanish wrote:Did you try solution from this post? http://forum.mirillis.com/viewtopic.php?p=40226#p40226
I must recheck, but it seems working like this for me:
-Start the game
-Alt+Tab, go and Open Action!
-Alt+Tab and switch back to game
If I restart the game with Action!already opened or Start Action! before opening any steam game, the Steam's GameOverlayUI won't work.
