Vanishingpointxd
PC Specification: i5 3.30, saphhire 6780, windows 7
Can't for my life remove action [BUG]
Fri Aug 16, 2013 2:47 am
i've trying to fix this problem I have been having and is really stressful because it seems that this should be easy to fix. I first installed action perfectly the first try and everything was fine and recordings were nice and smooth and wonderful quality but after I was looking around some settings i think and suddenly nothing would record ingame. After trying to discover the problem I found out it was the hotkeys that got messed up. When i first startup action i can enable/disable the hotkeys except for the top 4 key (the main ones) (Everytime i startup action it starts with every hotkey off even the top 4) . Then after some time the hotkeys just stop responding in the disabled position. I've tried reinstalling action multiple times (normally, using CCleaner for registry after, using a brute force uninstaller, deleting the 2 mirillis folders in appdata under local and roaming, and I've deleted the folder common files). Even after ALL that when I reinstalled, it still remembered where to put the recordings, microphone set to pressed, and all the hotkeys are still disabled :shock: . I'm at a complete lost here in I'm really losing faith in this program. :cry:
RazrBit
PC Specification: I7-3770K, HD6950, 8 x64, 8GB
Re: Can't for my life remove action [BUG]
Fri Aug 16, 2013 8:22 am
The settings are saved in registry: HKEY_CURRENT_USER\Software\Mirillis\Action
Vanishingpointxd
Fri Aug 16, 2013 5:40 pm
THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I'm SOOOOOOOOOOO happy this fixed my problem and i can use this wonderful piece of software once again. All i did was delete the hotkeys files in registry and the allowed ones and this fixed that bug :D . I'm sure it was only a glitch but thank god it can be fixed. Thanks again. :D :D :D
iamegg
PC Specification: I7 2600K 2ndgen / crossfire HD 6870/Win7
Sun Aug 18, 2013 5:55 pm
I Have same problem, ive tried deleting hotkeys on regedit but after one recorinding it still all hotkeys are re-disabled, not sure what to do
Mon Aug 19, 2013 7:59 am
iamegg wrote:I Have same problem, ive tried deleting hotkeys on regedit but after one recorinding it still all hotkeys are re-disabled, not sure what to do
Please contact our support team directly via support@mirillis.com.
Vanishingpointxd
Tue Aug 20, 2013 12:46 am
If you guys find a solution can you post it here? Sadly that was also a very temporary fix for me too. :/
RazrBit
Tue Aug 20, 2013 7:34 am
Vanishingpointxd wrote:If you guys find a solution can you post it here? Sadly that was also a very temporary fix for me too. :/
Action! 1.15.1 doesn't have this issue, so for the time being you can downgrade it, if you don't care about the live stream fixes.
iamegg
Tue Aug 20, 2013 12:18 pm
How does on downgrade it? :D
