TheRA1DER
PC Specification: ASROCK Z77 PRO3+HD6970+i7-3770K+Win 7x64
No system sounds "desktop" & "region" modes + Broken videos
Sun Aug 18, 2013 11:49 pm
Like the topic says, i dont have windows sounds while recording in desktop and region mode, everything else works fine.
Also, the other day i was recording PAYDAY2 gameplay, and i made 7 videos in a row, but the final 4 can't be opened in sony vegas and they play without any sound on Windows Media Player. Also, when i try to watch them in VLC media player i get this error: VLC does not support the audio or video format: 'FICV' ". When i click the files in windows explorer, i only get how much disk space they occupy, but i dont have the video duration information, just like when i have a corrupted video file.
I didnt change any setting, it just randomly happened.
Vanishingpointxd
PC Specification: i5 3.30, saphhire 6780, windows 7
Re: No system sounds "desktop" & "region" modes + Broken vid
Tue Aug 20, 2013 12:57 am
Im pretty sure you need to export the files first by right clicking the thumbnail of your videos in your main action! interface.
TheRA1DER
Thu Aug 22, 2013 12:22 pm
Vanishingpointxd wrote:Im pretty sure you need to export the files first by right clicking the thumbnail of your videos in your main action! interface.
but i never had to do that before :O
thanks for the tip, will try and update this later when i get the results.
Cheers
EDIT: Nope, did not work!
