ramon :D
PC Specification: Windows 7, AMD MSI HD 7870 GPU, AMD 8350
Action crashes every time I open!!! Please Help
Mon Aug 19, 2013 11:09 am
Hey, my copy of Mirillis Action has been an absolute delight to use but after recording about an hour's worth of Dead Space 3 it won't let me open it! It crashed as soon as I stopped recording. The recording was fine but I can't access the software :( It gives me the default 'Action! Has stopped working' message and tries to search for a fix but I never get any results (typical windows haha)
I am running on Windows 7 with an HD 7870 GPU and an AMD 8350 CPU in case that helps at all. I really want to record some footage but I can't even open it. If anyone can assist me I would be highly grateful!
Re: Action crashes every time I open!!! Please Help
Mon Aug 19, 2013 1:30 pm
Try deleting or moving to another location your output folder (where your recordings are stored). Then start Action!. If it runs properly that means there's a broken video in your output folder which cause Action! to crash.
