Pampperin
PC Specification: Windows 7
Can Action Record the Full Screen Without Showing a Task Bar
Tue Aug 20, 2013 2:36 am
Hello! I'm in love with your video program, it is simply amazing! But I have ran across an little obstacles, that I wonder if it could be fixed, or if there is a setting.
So I play a game called Minecraft.net (Minecraft) as many others and record Action with it. But in the game settings it does drops fps like all other recordings, but with screen recording it doesn't drop any, so I use the screen recorder instead to record.
The thing is, when recording in full screen (Pressing f11 in Minecraft) and hitting record for the full screen region recording, it shows my taskbar at the bottom, ontop of the minecraft window. With this I'm recording in a small window of Minecraft which doesn't make me as accurate as I normally am while playing in f11.
I was simply wondering if there is a way to hide the task bar at the bottom while recording the full screen region?
Re: Can Action Record the Full Screen Without Showing a Task
Wed Aug 21, 2013 10:53 am
Have you tried using Active Desktop Region?
Pampperin
Wed Aug 21, 2013 6:15 pm
radi wrote:Have you tried using Active Desktop Region?
It does this odd thing where I hit "f9" (Recording Key) in full screen of minecraft but it only records about half a second of the "Full screen" (which still shows the task bar) and then it records all of what I'm doing while my game is minimized, and when going back into f11 in the game, it doesn't show the game at all.
Pampperin
Sun Aug 25, 2013 3:22 am
Am I allowed to bump topics on here?
Tue Aug 27, 2013 1:47 pm
Pampperin wrote:Am I allowed to bump topics on here?
Sure, but if you haven't receive a reply for a while that means no one here can help you and you should try contacting our support team.
