"The file is of an unknown or unsupported file type"
please help
Eggy
Nop i recorded directly with quick syncVanishingpointxd wrote:did you export the file into mp4 first? You do this by right clicking the video thumbnail in action and selecting export
with quick sync as shown in the comment aboveradi wrote:MP4 with Intel Quick Sync or software encoding?
Yes the normal MP4 Files have the same problem, i record at 720pradi wrote:Thanks for the info. I informed the devs.
Could you please check if the software MP4 causes the same problem. What's your screen resolution that you record?
how do i check that?radi wrote:What's your Intel driver version?
In DxDiag report for example.iamegg wrote:how do i check that?radi wrote:What's your Intel driver version?
