nazuko786
PC Specification: msi laptop meets all requirments
action version 1.15.2 bug
Fri Aug 23, 2013 3:09 am
Hey I after I install the problem I press record it will work but after a few minutes like 20 or so it stops working I press the record button and nothing happens I looked at the forum and found a post saying the anti virus might be affecting it but I set action as a trusted problem its still not working I have to keep re installing to make it work whats up with that anyone found a solution to it?
Re: action version 1.15.2 bug
Tue Aug 27, 2013 1:53 pm
Update to 1.16.0. If your issue still remains contact our support team via support@mirillis.com.
