Action! 1.16.0 - 1.16.3
Fri Aug 23, 2013 4:41 pm
We are happy to announce that new Action! 1.16.0 is now available.
Download latest Action! version:
Full change list:
* New AVI recording engine (recordings are not lost when recorded application crashes)
* Fixed recording of videos with odd horizontal resolutions
* Fixed video scaling to 480p and 240p
* Stability improvements for NVIDIA GPUs
* GUI fixes
1.16.1 change list:
* Recording and streaming duration time added to HUD
* Fixed elapsed recording time accuracy (fixes recording duration problem)
* Fixed long Action! startup time
* GUI fixes
1.16.2 change list:
* IMPORTANT: Windows 8.1 RTM desktop and applications recording support added
* Fixed Action! not running in virtual machine environments
* Fixed hotkeys associations
* Allowed same hotkey association for microphone and webcam on key down recording
* H.264/AVC software video encoding improvements
* GUI improvements
1.16.3 change list:
* Fixed Windows 8.1 RTM desktop recording on PCs with NVIDIA/AMD PCI-E graphics card installed and Intel Quick Sync Video technology enabled.
* Optimized Action! startup time
* Improved D3D11 recording
* Fixed streaming startup with empty stream key
ObserverJLin
Re: Action! 1.16.0
Fri Aug 23, 2013 9:31 pm
Haven't tried it out yet but I'm sure it'll be great.
Another thing. You promised ages back when I initially requested it that mirillis would make an alternative smaller size/simplified overlay option (just the fps digits but with customizable size and colours when recording/not recording).
I would like to ask whether or not it is still in the works. If not please seriously consider it.
Thank you!
Laurent13
Re: Action! 1.16.0
Fri Aug 23, 2013 11:58 pm
Happy update everyone ! :D
How to use Intel Quick Sync ? if you know.. because youtube say to use it for better performance to prepare video for display on the Internet.
Disclaimer
PC Specification: i5-3570K 3.40GHz GTX 660Ti Win7 64 bit
Re: Action! 1.16.0
Sat Aug 24, 2013 7:33 pm
I'm getting an error saying this:
"Error opening file for writing:
C:\Program Files (x86)\Mirillis\Action!\Action.exe"
I keep hitting Retry and quitting and trying to update again but I keep getting this.
I always click to Run as Administrator but every time I open it I still have to Ok it to run. Is this the problem or something else?
Re: Action! 1.16.0
Tue Aug 27, 2013 1:48 pm
Run your installer after computer reboot.
Re: Action! 1.16.0 & 1.16.1
Thu Sep 12, 2013 4:56 pm
We are happy to announce that new Action! 1.16.1 is now available.
Full change list:
* GUI fixes
Laurent13
Thu Sep 12, 2013 9:08 pm
OMG :shock: Action Mirillis runs/boots so fast in comparison to 1.16.0 version.
Good job Mirillis Team
Miguel
Fri Sep 13, 2013 1:33 am
I can't launch 1.16.1, I got an error saying Action_x86.bin can't be run in a virtual machine, but it's not a VM :/
Back to 1.16.0.
Styo
PC Specification: CPU: FX-6300, HD5850, Windows 8 Pro x64
Fri Sep 13, 2013 5:56 am
After updating to the new version, the FPS in the top right corner does not show up. I tried changing the location to top left corner, no luck.
Sebastien.S
PC Specification: Gtx 560 ti , intel i5-2450 CPU 3.20 GHZ
Sat Sep 14, 2013 12:50 pm
Active desktop region recording mode doesn't work for me ...
