Tarik
PC Specification: Intel i3 HD graohics, windows 7
Motion2 with core i3
Sat Aug 24, 2013 8:13 am
Hi guys.
I have a core i3 3.2 GHz CPU which I believe has a dual cpu, and its intel first gen graphics, I dont have external card.
Question is will it be enough to handle Motion2 Ultra 1080p cranked up to 10 with detail and light boost cranked to 10 as well?
the other question is: what is the functionality of the "best quality 1080i to 1080p" option , and will do anything when I trigger it while playing a 720p???
Thanks :geek:
Tarik
Re: Motion2 with core i3
Wed Sep 04, 2013 8:38 pm
anyone?
Mon Sep 09, 2013 1:54 pm
Try contacting our support team via support@mirillis.com if you didn't receive any help here.
Vitory102030
PC Specification: Windows 11 Pro 22H2, Intel Core i7-12700
Mon Feb 09, 2026 4:04 pm
A Core i3 with first-gen Intel graphics might struggle to handle Motion2 Ultra at full 1080p with detail and light boost maxed out. Lowering some settings or using 720p content could help achieve smoother playback.
Return to “Picture²”
