djxput
PC Specification: 2700k, 7950, win 7
Been testing action ... Questions
Sun Aug 25, 2013 3:25 pm
I've been testing out various game recording software this past week and I'm quite impressed with Action. Although I have some issues.
1. Why does intel quick sync IQS only offer 1080p max resolution?
2. When testing just with action using shogun 2 as my base @75 fps without recording (paused screen). Using Avi (@ 2560x1440p) I get 69 FPS and 61 using IQS (1080p max it can do).
One would think that I should get better fps using IQS since I am using the HD3000 chip to help process. Strange thing is my file size using Avi is not much bigger then using IQS.
I have tested using a HD with a 160MB/s and also using a high speed ramdrive (currently using this also). No change with FPS.
Now when viewing the records - I cannot really tell if there is much of a difference quality wise (perhaps there is).
I would prefer to use the IQS record because I can watch the files easier outside of action. But as previously mentioned I get 8 fps less using IQS and let alone I cannot record at my natural screen resolution of 2560x1440.
my system:
2700k, 7950, 32 gigs of 2133 gskill ram.
any suggestions to using your product or as to why the Avi file would give me better FPS and similar compression for more resolution?
ps - Ive also tried Montago's batch file he has in this thread http://forum.mirillis.com/viewtopic.php?f=36&t=28847
makes no difference in the fps drop.
djxput
Re: Been testing action ... Questions
Tue Aug 27, 2013 9:32 pm
btw had more of a chance to 'mess' with things ...
the AVI format does take up more room - guess when the screen is paused it gives you weird results.
also Ive had time to fool around with Action, bandicam and DXtory - comparing them and their codecs.
DXtory and bandicam are similar in terms of codecs offered. Although bandicam you can use the intel quick sync and has a pause function and dxtory does not.
But a big thing with dxtory (compared to bandicam) is that you don't get as much of a fps drop even with the same settings with the x264 codec (which is strange).
Actions intel codec gives good quality and a small file size but only goes to 1080p.
I'm not sure which resolution I will be recording at 1440 or 1080 so this will come into play.
basically I want something that doesn't give a really huge file size if I record for an hour~
IMO if Action had the x264 codec with the ability to up the resolution to 1440p that would be perfect. As of now I may have to bounce between the 2 Action and DXtory depending on resolutions ... (I know the AVI can record at 1440p but the file sizes are a bit too big).
