RainbowUnicorn
PC Specification: Intel 3930K, GTX 680, Windows 7 ultimate
Videos exporting only sound into Sony Vegas ? Also not 60FPS
Tue Aug 27, 2013 2:33 am
I export my Videos recorded cause the raw recorded File Simply doesn't work when I put it into Sony Vegas Pro 12 and when I insert the Exported file it works to view but when I put it into Sony Vegas 12 either the Video doesn't work or the Audio. Also when I watch the Exported File it looks worse than I did in the Action! Video player also it doesn't export it in 60fps. I record in 1080p with 60FPS
PC SPECS
Sound Card ASUS Xonar Essence STX Virtual 7.1 Channel
Main Hard drive SAMSUNG 840 Series 500GB
Second drive TOSHIBA 3TB 7200 RPM RP
3rd drive Toshiba 7200RPM 500GB
CPU Intel Core i7-3930K
MotherBoard ASUS Rampage IV Extreme
GPU EVGA SuperClocked+ GeForce GTX 680 2GB
Ram G.SKILL Trident X Series 8GB DDR3 2800 (PC3 22400
Case CFI CFI-A7007 Black SECC
Monitor Dell UltraSharp U2412M
Re: Videos exporting only sound into Sony Vegas ? Also not 6
Tue Aug 27, 2013 1:42 pm
Could you upload somewhere your RAW file? I'm curious how it's different from mine which actually works with vegas.
RainbowUnicorn
Tue Aug 27, 2013 5:17 pm
https://docs.google.com/file/d/0BzVaaCJ ... sp=sharing Here is the exported File but I'll get the Raw file to you once I settle into my new placeement ( in the process of moving . )
Cauptain
Contact: ICQ
Wed Aug 28, 2013 5:37 am
Easy. Its directshow decoder problem, just iInstall LAV FILTERS or FFDSHOW. Its solve your problem.
Claudio
