hamster1er
PC Specification: I5 760;GTX 470;Asus Xonar DX;W7 64bit
Action! stops running while exporting
Fri Aug 30, 2013 2:36 pm
I have the latest version of Action!
I recorded some gameplay - 1080p @30 fps - but i didn't think to " manually " split the recording ( by stoping and restarting it every 10 minute )
it would be great if Action! can automatically split the vidéos, in 10~15 min parts for exemple.
So... I have a AVI file of 35 Gb .
With my comuter , Action! can export ( very well ) files of about 10~15Go in " 1080p Main profile - normal quality" but my 35Gb gameplay makes Actions crash and stop running after about 4 or 5 hours ( when the export is between 70 and 80% )
I tried with 1080p Main profile - Low quality and with different bitrate, but it keeps on crashing.
Also tried with 720p and differents settings but it the same. The files is just too big, i think...
What can i do ?
is there a way to split the files in two parts before exporting ? with Splash Pro for exemple ?
( is there any chance to edit the file with software like Adobe Premiere Pro ? because it's an AVI proprietary format from Mirillis )
Thanks for your answers and sorry for my english ( i'm French... )
