3p1c
PC Specification: i7 550 Ti Windows 8 64 bit
[BUG] Can't edit MP4/AVI unknown CODEC...
Sat Aug 31, 2013 3:39 pm
Dear, MirillisTeam, i just figured out, that here is a HUGE bug, i am a Editor, i recorded some Gameplay (Trickshots) and then i wanted to start to edit it, on Adobe After Effects CS6 on Sony Vegas 12 PRO, after i put these .avi files in AAE, i realized, the screen is BLACK, i put the Avi file in Sony Vegas PRO 12 , it said : German : beim öffnen eines codecs ist ein fehler aufgetreten
English(translated) : when one is open codecs an error occurred so AAE and Sony Vegas cant read the avi files, Please, make a fix i LOVE action!, its just Awesome. Thanks
-3p1c ;)
Re: [BUG] Can't edit MP4 unkown CODEC...
Mon Sep 02, 2013 2:53 pm
What's the resolution of your video file you are trying to import into editing software?
ericneo
PC Specification: 3770k, 680GTX, win7, 64bit
Tue Sep 03, 2013 9:38 am
I am having the same problem, it looks like the devs programmed additional DRM into the files which makes it unusable on converters and editors. I cannot even get the videos that I've recorded to convert with handbrake, so it's a big problem.
Tested for:
480.avi
480.mp4
720.avi
720.mp4 (with intel quick sync)
I haven't made a 1080 recording yet but assume it also has the problem.
Wed Sep 04, 2013 2:11 pm
Yea, but the resolution of your video. You can check this in Video Properties.
3p1c
Fri Sep 06, 2013 2:47 pm
Sorry that i didnt say anything, was not at home ^^.
1920x1080 (Original)
here some Pictures of the Problem:
AAE
no screen, only BLACK...
Sony Vegas PRO 12
cant Read the CODEC...
MY PC SPECS :
intel i7
Nvidia GT 440 TI
6GB RAM
Windows 8 64-Bit
3p1c
Re: [BUG] Can't edit MP4/AVI unknown CODEC...
Thu Sep 19, 2013 7:19 pm
Hello?, i think i waited long for a response... Please some1 help???
Cauptain
Contact: ICQ
Fri Sep 20, 2013 7:41 am
3p1c wrote:Hello?, i think i waited long for a response... Please some1 help???
Just install LAV Filters!!
Link: http://www.videohelp.com/tools/LAV-Filt ... on-history
Claudio
cibergatox
PC Specification: i7 3770k 780ti 16gbram Win 7
Mon Sep 23, 2013 8:17 pm
I'm also not getting video after exporting, can you elaborate more on that LAV filters solution?
