burny_s
PC Specification: 3770k, 670, 16gb
Action Not Exporting Full Clips
Sun Sep 01, 2013 11:01 am
Basically, I'm exporting my clips, various lengths from around 30 seconds to 15 minutes. Some come out fine, some export only a couple of minutes and some export half of the clip. The sound disappears near the end of the clips as well. This only seems to have come into affect last week, before that, everything was fine.
I'm using the auto preset, and exporting 1920x1080 on high. I've tried to use other presets but they seem to do the same. I did notice it helped if I only used a 5 minute clip, but still they sometimes failed to export the whole thing. Plus I don't want to be limited to that timescale.
Please could anyone suggest a fix, or a contact at Mirillis who can look at this for me?
Thanks in advance.
