BillyG
PC Specification: i7 3770K ASUSGTX 770 Windows 8 pro 64bit
Youtube HD Export???
Fri Sep 06, 2013 1:49 pm
I've recently bought Action software and I have to say the recording quality is superb but the problem I'm having is when I try to upload directly to YouTube through the built in export feature. I've been using the YouTube HD as my output file, my file type is avi and at 1920*1080p, the clip is about 4gb in size and only 2 minutes long. I would really appreciate some help here as I've been pulling my hair out all day as I've only just purchased action. I've also tried converting the raw avi files to h.264 with a converter program and then trying to upload that file to YouTube through my browser but I'm still having no luck as YouTube wont convert the file type. I've also tried recording using mp4 at 720p but the YouTube export feature still wont work and even if it did the video quality isn't really what i was hoping for, I also tried switching GPU coding off in case that tripped something but I just keep getting the same error message in Action that says 'upload failed'.
Any help would be awesome! ;)
BillyG
Re: Youtube HD Export???
Thu Sep 12, 2013 5:28 pm
Any help? Ive tried mirillis support they couldnt figure it out im guessig as ive had no reply for over a week now
Fri Sep 13, 2013 12:44 pm
Could you post a sample file here? I will try to upload it via my Action.
Laurent13
Fri Sep 13, 2013 3:16 pm
Cauptain
Contact: ICQ
Fri Sep 13, 2013 6:45 pm
radi wrote:Could you post a sample file here? I will try to upload it via my Action.
Get RIPBOT264, convert Action AVI file in MP4 using Profile 4.0 - Progressive.
For 1080p, try 8192 bitrate, 720p try 4096 or more.
Any file make on RP will upload withlem. Try and reply.
Claudio
