when i trying to stream with action 15.2 - I press F9 or the red button to start recording and doing live stream, and it does not begin to do, it does nothing
please help me
Hey, still i got this problemradi wrote:Update to 1.16.1 first.
Twitch and what do you mean?radi wrote:What the Status info says (first tab with "i" icon) when you press F9? To which site you are trying to stream?
Check if your stream key does not contain space bar at the end of your key. Paste it into notepad before you paste it into Action.scoFieldo wrote:Twitch and what do you mean?radi wrote:What the Status info says (first tab with "i" icon) when you press F9? To which site you are trying to stream?
hey, Even when I try to record, I do not do live stream, it does not start the captureradi wrote:Check if your stream key does not contain space bar at the end of your key. Paste it into notepad before you paste it into Action.scoFieldo wrote:Twitch and what do you mean?radi wrote:What the Status info says (first tab with "i" icon) when you press F9? To which site you are trying to stream?
In that case you should contact our support team via support@mirillis.com.scoFieldo wrote:hey, Even when I try to record, I do not do live stream, it does not start the capture
