ROBBOsulsu
PC Specification: Windows 7
Noise cancelling?
Sun Sep 15, 2013 3:23 pm
Hey Mirillis!
So, I've just noticed that other recording softwares on the market have the ability to use Noise Cancelling for microphones, To prevent stuff like Keyboard clicking for example.
I was wondering will this feature be implanted into Action! or if not, Does anybody know how I can remove the background noises from my video's?
Thank you!
Re: Noise cancelling?
Tue Sep 17, 2013 12:06 pm
I don't remember someone mentioning this feature before. I can add it to our users wishlist.
ROBBOsulsu
Sun Sep 22, 2013 10:51 pm
Thank You So Much!
:D
Laurent13
Mon Sep 23, 2013 2:02 am
It will be a great idea but, maybe noise can to be remove a lot or cancelling by connecting the microphone in sound card but, let's try it within Action! :geek:
ROBBOsulsu
Mon Sep 23, 2013 8:08 pm
That could work yeah, Problem is I use a Blue Yeti Microphone which is USB. So I dont really have that option unfortunately :( But that's a good tip for anybody who can :D
Laurent13
Wed Sep 25, 2013 12:23 am
ROBBOsulsu wrote:That could work yeah, Problem is I use a Blue Yeti Microphone which is USB. So I dont really have that option unfortunately :( But that's a good tip for anybody who can :D
Did you made a video on youtube to listen the noise ?
Users browsing this forum: No registered users and 54 guests
